Hitting rev limiter to early? HELP?
early fall last year i had the crank assembly replaced on my 05 450x and rode her 5 times with no problems but on the very start of the 6th ride she was hitting "and im guessing the rev limiter" way to soon. I would say its hitting the limiter 50% sooner than it should in every gear
she still starts fairly easy and idles fine with good power at begining of each gear but after the 40% mark she starts to backfire a little and feels like it's hitting the rev limiter?
any Ideas?
Thanks?
Ok well it wasn't the carb so from what ive read on some other threads im thinking its a bad cdi, so my question is will my friend's 2006 cfr450 R cdi work on my 05 crf450 X to test and see if this will correct my problem?
Thanks?
