YX 140 engine mods
i was wondering what the best mods to the yx 140 are. i've heard head work is where you will get most of the power. are there big bores for these motors? and what is the most HP you can get out of these 140's, and still be reliable??
thanks.
thanks.
this question has been asked a few times recently check the search option....?
Which of the cams mentioned give the 140 motors the Same type of power just more of it. I am looking at getting a cam but want one that doesnt change the power(IE more low end but takes away from mid and top and vise verus) but just adds more of the same type of power the 140 already has.
im lookin at one on ebay right now....
has a lightin stator...heck yeah!!
so....it should fit right in my mad max correct?
what is the engine length so i can make some measurements before i buy....
all these motors (Lifan, Jialing (GPX), Yx and Zongshen) are all CRf50 based Case motors and will fit into any bike that has a Horizontal CRf50 based motor in it.
things that maybe needed:
Pipe, Wider foot peg bracket (most aftermarket work) different skid plate (when going from CRf to Yx) Longer or shorter fuel lines and longer throttle cables (usually) and possible that a bracket may need to be made (pipe hanger)
