KTM 50 forks on a CRF50??
I'm sure someone will correct me if I'm wrong, but I think if I were to attempt that, I would:
1. Get aftermarket tree for a xr/crf50 that holds the same mm size fork tube as the KTM fork. Maybe the next size bigger even( say 33mm fork, 34mm tree) and use shims to make the fork tube fit the tree.
2. Your done.
i think the space between the forks will be too small to fit the wheel in.
The width is determined by the tree, witch was made for a xr/crf50. After that it would only be narrower if the lower fork axle hole is thicker. So you would just have to make bigger or smaller axle spacers.
By the way, I do own a Honda CRF50 and a KTM 50.
