Calipers to measure shims?
When you pull a shim, what do you use to measure the thickness?
I've got a 0-1" OD mic, but I have to convert (what a PITA). I've also got a cheap set of dial calipers that I use for woodworking - not accurate enough. I'd like to get a digital set that handles MM, but I'm not 100% sure I want to invest in a Starrett..
Any suggestions? (Can I find it on Amazon - that'd be even cooler!)
save yourself the money and just print out a conversion table for each shim. Then you just need to look at the sheet :applause: If you're going to buy calipers to measure them with, buy a really good set so that you get the resolution you need in your measurments.
This is all you need with part #'s.
Thanks to RR.
14901-MBB-000 .0472in 1.20mm
14902-MBB-000 .0482in 1.225mm
14903-MBB-000 .0492in 1.25mm
14904-MBB-000 .0502in 1.275mm
14905-MBB-000 .0512in 1.30mm
14906-MBB-000 .0522in 1.325mm
14907-MBB-000 .0531in 1.35mm
14908-MBB-000 .0541in 1.375mm
14909-MBB-000 .0551in 1.40mm
14910-MBB-000 .0561in 1.425mm
14911-MBB-000 .0571in 1.45mm
14912-MBB-000 .0581in 1.475mm
14913-MBB-000 .0591in 1.50mm
14914-MBB-000 .0600in 1.525mm
14915-MBB-000 .0610in 1.55mm
14916-MBB-000 .0620in 1.575mm
14917-MBB-000 .0630in 1.60mm
14918-MBB-000 .0640in 1.625mm
14919-MBB-000 .0650in 1.65mm
14920-MBB-000 .0659in 1.675mm
14921-MBB-000 .0669in 1.70mm
14922-MBB-000 .0679in 1.725mm
14923-MBB-000 .0689in 1.75mm
14924-MBB-000 .0699in 1.775mm
14925-MBB-000 .0709in 1.80mm
14926-MBB-000 .0719in 1.825mm
14927-MBB-000 .0728in 1.85mm
14928-MBB-000 .0738in 1.875mm
14929-MBB-000 .0748in 1.90mm
14930-MBB-000 .0758in 1.925mm
14931-MBB-000 .0768in 1.95mm
14932-MBB-000 .0778in 1.975mm
14933-MBB-000 .0787in 2.00mm
14934-MBB-000 .0797in 2.025mm
14935-MBB-000 .0807in 2.05mm
14936-MBB-000 .0817in 2.075mm
14937-MBB-000 .0827in 2.10mm
14938-MBB-000 .0837in 2.125mm
14939-MBB-000 .0846in 2.15mm
14940-MBB-000 .0856in 2.175mm
14941-MBB-000 .0866in 2.20mm
14942-MBB-000 .0876in 2.225mm
14943-MBB-000 .0886in 2.25mm
14944-MBB-000 .0896in 2.275mm
14945-MBB-000 .0906in 2.30mm
14946-MBB-000 .0915in 2.325mm
14947-MBB-000 .0925in 2.35mm
14948-MBB-000 .0935in 2.375mm
14949-MBB-000 .0945in 2.40mm
14950-MBB-000 .0955in 2.425mm
14951-MBB-000 .0965in 2.45mm
14952-MEB-000 .0974in 2.475mm
14953-MEB-000 .0984in 2.50mm
14954-MEB-000 .0994in 2.525mm
14955-MEB-000 .1004in 2.55mm
14956-MEB-000 .1014in 2.575mm
14957-MEB-000 .1024in 2.60mm
14958-MEB-000 .1033in 2.625mm
14959-MEB-000 .1043in 2.65mm
14960-MEB-000 .1053in 2.675mm
14961-MEB-000 .1063in 2.70mm
14962-MEB-000 .1073in 2.725mm
14963-MEB-000 .1083in 2.75mm
14964-MEB-000 .1093in 2.775mm
14965-MEB-000 .1102in 2.80mm
14966-MEB-000 .1112in 2.825mm
14967-MEB-000 .1122in 2.85mm
14968-MEB-000 .1132in 2.875mm
14969-MEB-000 .1142in 2.90mm
14970-MEB-000 .1152in 2.925mm
14971-MEB-000 .1161in 2.95mm
14972-MEB-000 .1171in 2.975mm
14973-MEB-000 .1181in 3.00mm
These are all the valve shims available for the CRF. The shims are marked in mm but they are rounded to three digits: 1.825mm is acutally 182 on the shim and 1.875mm would be marked 188. As far as the measurements in inches, I carried them out four places. If I would have rounded them, you end up with two different shims with the same english measurement. Must be the shift between the two standards I guess. RR.
