Nissin caliper identification
A previous owner changed the oem caliper on my 2009 WR250X.
Yamaha tried 3 times, based on the part numbers their system gave them.
Oem brake pad is 8mm shorter and 2mm wider. When comparing the used EBC, with the new EBC.
Is there a chart available somewhere that I am not finding?
Thanks 20250526_170156.jpg.3a1e7e28b2470fa9376b06a6d23024de.jpg20250524_084129.thumb.jpg.a57e092dc134df29a18cea0d1cc49225.jpg
Posted (edited)
Here's an EBC pdf list for all their brake pads. Your FA185's shown in there are posted as 94 x 34 x 7. So taking the measurement differential, you'll have to search through the other pads and find a 102 x 36 x 7 (?) in the correct configuration based on accurate measurements taken off your existing pads.
https://www.ebcbrakes.com/wp-content/uploads/2023/11/EBC_UK_PAD_BUYERS_GUIDE_203.pdf
Edited by 76xtdrvr
Thanks for that,  but I just got back from a shop a little further away.
They had the EBC catalog. It contains actual size outline/shadow drawing that you can match the brake pad in question.
Wolla!  It's a caliber from a cbr600.
Hopefully this post helps others in the future
  • Like 2
