Throttle Sticking Even with new throttle tube
1 minute ago, Nato52 said:
Pretty sure it has to do with the bars. Is there any way I can fix this without replacing my bars, they don't look bent and only have 30 hours on them. I just blew 30$ on a throttle body and can't afford new bars at the moment. I'm also not the guy to ride at a track with a sticky throttle so If it requires a replacement I might not be riding for a while.
I'd be supervised that say 8" of the bar where the throttle tube goes on is bent but nothing surprises me anymore.
Just and example red line.
As posted use a ruler to check its not bent and if the ruler does not sit flat on that part of the bar post a pic with the ruler showing where its not flat.
These aren't the best of photos but I think they give you a general idea. The ruler was basically straight the entire handlebar. I applied even pressure and didn't notice anything. Maybe I should of push the throttle back a bit to give the ruler more space. There is also 2 more photos I took with all the rulers wait focuses on the left of the ruler. The first nothing looked odd, and the second had a little bit of space; However, this one I might of had the ruler a bit off the bar and possibly too much force. These are the photos I got, I'm completely in the dark so I'll probably mess with it more tomorrow and see what I can try to do.
Also If this means anything: when I have the tube half on the bar It spins freely and the more I push it on the bar the more freeness it looses and when all the way in becomes very tight ?
Edited by Nato52
11 minutes ago, William1 said:
Yup. There is no way to file down the bars enough to make up for the bend.
Question, since I need new bars how do I know which size bars to get? I'm looking at mika bars as there only 50$ There's a option for "Kaw Stock (997)" I'm pretty sure that's what I need but I'd like to know how to find the right size as I rather not pay 50$ for the wrong size bars. (Kx 85 2020)
I've never needed to replace bars so this is a first for me ?
Edited by Nato52
Cannot answer. You buy OEM Kawasaki bars and you will know they are identical. Any aftermarket, you have depend on the information from the reseller.
Bars will be 7/8" or 1-1/8: at the bar clamps and pretty sure yours are 7/8" and have a cross bar.
All bars are 7/8" at the ends.
Anyway did you crash really hard on the right recently?
This pic looks like the bars are bent about 1/8" at the right/end compared to where the tube/housing would be around the left which IMO would stop the tube from spinning freely.
IMO you could try have someone hold the bike and use a solid bar inside the end of the bar about 3" in and bend it up a bit at a time until the tube spins but TRY is the word and not sure how that would work.
Personally I would not try and straighten a bent bar and just buy a new one from the 100's of choices.
https://www.rockymountainatvmc.com/rm-rider-exchange/handlebar-information/
Edited by PhilthyX
I'd say the most hard crash I've ever had sense I got it was when I was in 2nd on this small jump section of a mx track. It was muddy and I lost traction mid  jump face, luckily I was planning to take a break and was going slow as I was close to track exit so I'd did a one second superman and my bike hit the throttle side. I'm just disappointed my bars would bend that easily ?
