Pro Circuit R-304 vs. Factory Sound 304
So whats the performance differences between these silencers?  I am starting to buy parts for my soon to arrive 2015 YZ250 so I have everything ready to bolt on before I ride it.
If it matters any, it will be paired up to a Pro Circuit Platinum pipe with a Pro circuit pump gas ported motor.
Edited by intensem1rider
Pretty sure you mean silencers, not pipes. I have a plat and plat 2, both using the r304(non shorty). The plat is a screamer and the plat 2 puts out more on the bottom and is way stronger/tougher. I like both pipes, but the plat bends like a alum can compared to the plat 2. I like the plat 2 better cuz I ride mostly singletrack. For dune/desert I'd rec the plat, except that it bends so easy. Not a lot of difference between the two pipes, but it is noticeable. My plat is so bent up right now that I'm not even using it btw
