Ways to stop the foot pegs from ripping out? klx110
  • 5 weeks later...
  • TT Sponsor
TRC Cradle-Mount Frame KLX/DRZ110's & KLX110L
Part No: TRC-0819
  • TRC-KLX110-Cradle-Mount-2.jpg&h=171&w=25
  • TRC-KLX110-Cradle-Mount-1.jpg&h=154&w=25
  • TRC-KLX110-Cradle-Mount-3.jpg&h=208&w=25
  • TRC-KLX110-Cradle-Mount-4.jpg&h=156&w=25
  • TRC-KLX110-Cradle-Mount-5.jpg&h=161&w=25
  • IMG_7262.jpg&h=375&w=250&zc=1
TRC Cradle Mount frame Adaptor fits KLX/DRZ110's & KLX110L
The kit comes with all the hardware to bolt it to your frame or you can have it welded on for added strength and protection.
Benefits:
* Added support to your motor (no more broken motor mounts)
* Added strength to foot pegs (no more bent foot peg mounts)
Features:
* Laser Cut Process
* Tig Welded
* Black painted coat finish
* Mounting hardware included
This modification to your Pit Bike or Mini is still AMA legal as an open frame setup.
Fits ALL KLX110 & KLX110L
  • 3 months later...
  • 1 year later...
Whatever you do don't add too long of a bolt. You'll run the risk of popping through the case to the inside of the motor and then have a few more holes to drain oil lol. I bought an 06 110 and found out that the previous owner did that so when I went to take the footpeg mount off oil spilled all over the floor. Ended up having to split the cases to plug the holes. That gave me the opportunity to add new transmission bearings and upgrade to a 4 speed shift drum though
  • 3 weeks later...
  • 1 month later...
Not to thread jack, but Im probably going to order the cradle for mine as well, but I want bigger pegs and over the top rear brake lever, anyone have recommendations as to what will work with the cradle? And I see skid plates as well that I would like to add, is there any that work best with the cradle mount as well?
Any aftermarket mount will work with the cradle
