yz fork and shock interchange
No, it doesn't hit.....where it was in the first picture is about as close as it gets. I can push it farther away about 1/4 inch. The top shock bearing is going to limit any radial movement...no matter on the stand or at full compression. Moving thru the stroke, the shock does move fore or aft, but it splays out (a word?) during compression..... moving even farther away from the frame.
Clear as mud?
I'm going to attempt to break these options down into a digestible form:
Your options depend on how dedicated you are to keeping the YZ400, and after that, what condition the current fork is in. There is very little to be gained by changing forks from what you have to any alternative other than the '06 or later. The '05 can be made to work as well as the '06, but it takes time and money. The '06 fork will cost you less than rebuilding yours with the Race Tech kit, and while you won't learn as much that way, the stock '06 will be a much better setup.
But let me float this one: If you really don't want to spend that much on it, either just rebuild yours as they are, or...
Clean it up, sell it, and buy an '06 running and ready. You can get one for as little as $2k these days, and if all you can get for yours is $800, that's a hell of an upgrade for a $1200 net.
moto2000 so you're saying that the 2007 shock might very well fit my bike?
Did you experience a noticable improvement with that shock vs. the stock one?
That depends on how much clearance you are comfortable with.
If you already have an '07 shock I'd say yes, but install it on your bike without the spring and move the swingarm through the full length of its travel. If you can keep at least a quarter inch of clearance around the shock body I'd say your golden. If it's less than a quarter inch, I would be concerned. The frame will bend and deflect as you hit things and that eighth inch may dwindle to nothing under dynamic loads.
If you don't already have a shock in hand, personnaly, I would feel more confident using a shock from a steel frame bike. But that all depends on price. If you can get an '07 or later shock for really cheap, it might be woth the risk. The ony functional difference between the '05 YZ shock and the '07 is a little more oil volume.
Thanks for all the input guys.
I called race tech yesterday to order parts for my forks and shock. I decided just to do a refreshing of the OE parts. Maybe at a later time I can upgrade to the gold valves, but right now its just not feasible. The price for all the seals, bushings, heads, oil, and a few special tools ran up to almost $400 before shipping...I just can't justify spending another 400 on the gold valves right now. At any rate, I think just going through the suspension and replacing the oil and seals will probably make a noticeable difference compared to the worn out junk that I am currently running.
Correct. Refreshing your clapped out suspension isn't going to do anything but good things for your ride.:bonk:
Well I've gone through the suspension and now it feels much better!
I ended up going with a race tech setup for the rear shock (I found a gold valve on ebay for $110 so I went for it). I also purchased Racetech's recommended springs and I must say now the bike feels a lot better. cornering is easier to boot.
For the front I just replaced the seals/bushings and fluids.
When I first got on the bike to set the sag the bike felt really stiff, like something was weird with the shock. Anyway I went ahead and set the sag and went riding yesterday. One thing for sure the shock freed up quite a bit after riding for a few mins. I will re-check the sag before I go out riding again.
  • 5 years later...
  • 1 year later...
1 hour ago, Kyle Dietrich said:
Will the forks off my 2006 yZ250 F
fit my 2001 yz125?
Direct bolt on no,
but with the correct triple clamp, steering stem, axle & spacers no doubt yes.
As ss-racing suggested above, stock 4-stroke fork settings are likely too stiff for a light 125, spring rates and valving.
Edited by mlatour
  • 4 weeks later...
  • 3 years later...
On 12/21/2011 at 1:00 AM, grayracer513 said:
That's true. There are some minor differences in length, but they work.
Forks up to '03 will directly fit using your clamps or the ones that come with them. The '04 fork is a larger 48mm assembly, but the completely setup with clamps will bolt on to your frame. Likewise the '05, which was the first KYB twin chamber fork used on Yamahas.
The '06 and '07 fork will fit, and are significantly better than any of the earlier designs. You need to use the '06/7 clamps though. Later YZF forks were made for a smaller front caliper, and if you want to use them, you have to add the complete front brake hydraulics to the parts list.
Can anyone tell me if the forks from a 2004 YZ250 will fit up to a 2014 YZ450? Just wondering if they will bolt straight into the triple clamps.
Cheers
sorry about the resurrection
After all that you are doing the right thing.  Often trying to upgrade to a newer shock or forks is far more work than just rebuilding the existing components with upgraded parts without much of a change.  On a bike that old you are going to have other problems to deal with and money to be spent.
Keep in mind that even if everything bolts up, the internal setup for each application is different,
the YZ250 being lighter than the YZ450 so spring rates and valving to match.
