03 yz450 cam timing with aftermarket stator cover.
So, I tore down my engine to install a 5 speed from a WR and forgot to mark the cam timing marks in refrence to the crank location.
I do not have the stock stator cover with the timing marks for the flywheel. how do i go about installing the cams on the bike without using the original timing marks?
-Dan
Find TDC by probing for the piston crown through the spark plug hole.
You can actually feel TDC as you rotate the crank past it.
Thanks grey, I did that this morning and kicked it for a half hour, its still not catching and sometimes ill get a bit of fire out of the exhaust, but never feels like its catching. Ill take a picture later today to see if its correct.
-Dan
