Followers 0
10wr450
what fork springs for a 10' wr450
4 posts in this topic
hi , new member here in need of some help. wondering what fork springs you heavier guys are using on the 07-10 wr's. i need a set of .50kg\mm , was looking at the factory connection lsb050's which are listed for the bike but there site says they are 450mm long but the stock ones are 460mm with the worn out limit at 455mm. does anyone know if these are the correct spring?:thumbsup:
just put a 10mm spacer in before you put the fork springs in
I'm running YZ450 springs with a 455mm free length, with a 5mm spacer to make up the difference
Followers 0
