ATF fluid inplace of fork oil
Ya right, tell that to a torque convertor. What do you think drives your 6000lb pickup down the road. Answer ATF fluid. You might what to have a look at how an automatic tranny works. Here is something to get you started
http://en.wikipedia.org/wiki/Fluid_coupling
+2 you beat me to your answer. I have used ATF oil in the past with good results. I'm not using it in the cartrige fork because I like a lighter w oil then any published ATF oil weight that I have found. I have thought about using it in the outer chamber.
Try it out, if you like the feel than go with it. IMO it can't harm anything.
