Followers 0
carbonkid
Stock Magneto timing on 2000 426
2 posts in this topic
Anyone Know the stock Magneto timing when the pick up passes. (example 26 degrees btdc) I can not find any thing in the 2000 426 factory manuel.:moon:
It's probably marked on the flywheel. TDC is a single vertical line. The 2-3 degree zone where the ignition is supposed to fire is indicated by a pair of vertical lines connected by a small horizontal so that the whole thing looks a bit like an 'H'. It can't be adjusted, and is controlled by the CDI, based on the RPM signal and the TPS signal.
Followers 0
