Flatland guards and shroud fitment
Just installed a set of Flatland rad guards on a 05'. Question is can you ever get the bottom shroud bolt to mate up with the radiator without really flexing the shroud hard? Theres a good size gap between the plastic and radiator and when it's drawn in with the bolt it really flexes the shroud hard. I trimmed the rib thickness down about a 1/4", if I cut the ribs completely down will the the shroud ever mate up flush?
Thanks
If it's anything like the unabikers you'll have to put a longer bolt and a spacer there.
i have the moose/enduro engineering and they also use a longer bolt and spacer
There should have been spacers and longer bolts included. I have Flatland guards on my '07 and they fit very well. They have saved the rad's several times. :moon:
Longer bolts were provided. I trimmed some more plastic off and it fits a little better, good enough.
Flatland on '06 no problems.
