HEADS UP!!!
Site upgrade in progress... Core site functions are working, but some non-critical features/functions will be temporarily unavailable while we work to restore them over the next couple of weeks.
Please post any bugs you encounter, but before you do, check to see if it's already listed.
Thanks for your patience while we work to improve the community.
Followers 0
konoplia
WR400 waterpump
5 posts in this topic
When I run my wr, cooling liquid leaking from the small hole which I have found below the pump. What is an issue?
Please help? What to do?
Leaking water pump seal. Time for a new seal, good idea to replace the shaft as well as that is what often causes the seal to leak. Not a bad job, not even too expensive.
Followers 0
