Whitch Way!!!!! Help Asap!
HAHAHA so i removing my drive sprocket on my 426 and i was just wondering witch way it spins right or left? ITS ON THERE!!!:banghead:
the nut spins counter clockways
THANKS MAN!!!
ok so this damn nut is on there, i am going the right way (to loosen you turn left counter clockwise) so is it ok to use a impact gun?
I always use an air impact driver. Did you bend the washer flat first?
bend the washer first, then put it in first gear and use a 27mm. wrench... at least I did it today and worked perfectly...
PB Blaster helps. Soak it, drink a beer, come back.
I have never gotten one off without a impact gun and try out "aerokroil" as a lubricant stuff is amazing you can find it a any industrial bearing shop.
HAHAHA I got it guys it all wrked out good, i borrowed my bro's impacked, worked wonders!!
Theanks guys for all your help!:banghead:
I always just hold the rear brake when I loosen and re-tighten the nut...
If you have no impact wrench available, and the nut's being stubborn, roll the chain back over (if you've taken it off) and lay a sturdy piece of wood or a hammer handle across the swing arm to lock the wheel. Absolutely works.
