Followers 0
SOW1
grey wire, were dose it unplug?
3 posts in this topic
Is there a place to unplug it or do I have to cut and make my own plug?
The only plug with a grey wire is in a multi wire connector, is there a plug I am not seeing
On a WR426, its under the tank. There are 2 maybe 3 conncetors, one has about 8 wires to it. The gray wire that needs to be undone is part of a 2 wire connector. Run a paper clip into either side of the connector to release the catch for the terminal and pull it out of the connector and tape it to the outside real well in case you want to put it back at some point.
Followers 0
