Followers 0
honda0071
porblem... mayb front wheel bearing?
6 posts in this topic
Put the bike on a stand, spin the front wheel.
If it makes noise try removing the front brake caliper (2 bolts)
Spin again....if it still makes noise its your bearings.
Anybrand will be fine. Check Rockymountain.com or thumpertalk store
Usually you check your wheel bearings anytime you have the wheel off the bike. When the wheel is off the bike stick your thumb in the hole and turn it. It should be nice and smooth with no lateral movement. It is feels bumpy or uneven when rolling it is time for new bearings. It it makes a noise its real bad:cry:
If your back wheel bearing spins nice and smooth there is no reason to replace them.
And anytime you put a wheel back on puts lots of waterproof grease in the hole around the bearing for longer life.
There should be a step by step to replace bearings somewhere on this site.
Followers 0
