gearing help
I have a 2008 Yz450F and went from a 49 to a 50.
Now i have a 12:75:1 piston and a rekluse clutch that i like very much.
For this wekend i will probly put a DR.D pipe on i just bought.
I do not think the 50 felt good even when i changed to it.
I would like to try something different.
Make some suggestion's
Greg
Why do you want to regear it in the first place?
I race at least 2 times a month and run both the Rekluse and DRD pipe. I race both desert and MX at the expert level. I almost always run the stock gearing with the only exceptions being a really fast desert race with a lot of high speed roads. Even then I don't use tall gearing for higher speeds, I just want the same speeds at less RPM's. When I race something like Idaho City (which is very tight and technical) I will run much lower gearing.
Also a heavy flywheel works really well with the Rekluse.
