HEADS UP!!!
Site upgrade in progress... Core site functions are working, but some non-critical features/functions will be temporarily unavailable while we work to restore them over the next couple of weeks.
Please post any bugs you encounter, but before you do, check to see if it's already listed.
Thanks for your patience while we work to improve the community.
Followers 0
henrics
wr450 jets, what are they?
3 posts in this topic
Have just removed the ais from the bike and i shuold probably rejet.
Open endcap (pro moto billet style),airbox snorkle removed, sea level.
yz throttle stop.
There was a few jets with the bike,these came in a plasic bag
should i use them?
175 mj
50 pj
45 lj
110 ?? fits at nr 2 in the picture below there in no jet there now(stock)
stock jets where
mj 162
pj 45
60 lj
#70 in the nr 1 in picture
empty in nr 2 in picture
What are nr 1 and nr 2 in the picture when should i mess with them??
Is this right then, the starter jet is only activated when the choke is on.
yz throttle stop.
should i use them?
175 mj
50 pj
45 lj
stock jets where
mj 162
pj 45
60 lj
You will probably never need the 50 pj or 175 mj. The 45 lj could be used. I switch between a 52 and a 40, depending on weather. The main air jet is the #2 pic and is fixed, I believe at 200. I don't think you'll need to change it. The 70 (pic 2) is the pilot air jet and you only change it if you mod the ACV to YZ spec by blocking it closed (it can also be blocked open), but then you'll need a smaller pj, too. (you have an EU bike, so I don't know if this applies to you.)
Both air jets control vacuum at their respective jets and alter how much fuel gets pulled through them.
Yes, starter jet only works with choke on.
Thanks
A quick and precise (spelling) answer.
Is there any advantage with removing the ACV?
Followers 0
