valve adjustment
hey how much is it for a normal valve job at a shop give me an estimate price...
Your thread title says "valve adjustment" and your post says "valve job", are you having them adjusted or replaced?
I think it is $225 for full race prep, including valves, oil, filter, air filter, lube cables, etc. at Langston. Valve clearances alone are probably $75 if no shimming required.
Learn to do it yourself by reading the most recent Dirt Rider and posts in this forum. You will easily pay for the few special tools (torque wrench and feeler gauges) on just one service. It will take you an hour to check them and maybe 90 minutes if you have to re-shim. After doing it a time or two you will be able to check them in 30-45 minutes.
