grey wire on 04 wr450
I would like to disconnect this wire could any body tell me where it is located I have a 04 wr450 thanks Greg:excuseme: :banghead:
Look at the 6 pin connecter @ upper right of tank. The wr mod forums at the top of the page will guide you through almost everything.:banghead:
Clip the wire a couple of inches out of the connector and solder in wires up to a water-resistant switch near the headlight. That way you can turn it on and off but I have found I like the way it runs better clipped. Seems to have more torque at lower RPMs.
