PWR Stage 3 Cooling Kit
We have currently acquired a radiator kit , the hoses ar cool and they bolt on fairly well but there are a few anomilies,
1)the oil hoses ar too short, the hoses that link to the cooler are abot 3/4 " too short.:banghead:
to add to this, the bottom "coolant equaliser pipe" on the right hand radiator has no partner on the left hand tank to connect to. :busted:
then the gap between the inner oil fitting and the rocker cover is at best 12mm ,leaving no place to connect the return feed hose (yes even if it was long enough:banghead: )
can any body help:confused:
to add to this, the bottom "coolant equaliser pipe" on the right hand radiator has no partner on the left hand tank to connect to. :D
Did you acquire the kit from PWR?:busted:
