'08 450 Sag and fork height
Curious as to where people are running sag and fork height on the '08 450. I ride mostly MX and had the suspension done by Pro Action. I'm currently running the sag at 95mm with the forks set at the factory line in the t-clamps. From reading on here, the '07 magic spot seemed to be 95-97mm sag with forks raised 5-6mm, but I know the '08's geometry has changed. Thanks!
Im not exactly the guy to give you the right answer on this, but im running my sag at around 100mm and my forks are raised about 5 mm. Seems to be ok. Would i actually notice a difference between 100mm and 95mm? If so, what would the difference feel like.
