HEADS UP!!!
Site upgrade in progress... Core site functions are working, but some non-critical features/functions will be temporarily unavailable while we work to restore them over the next couple of weeks.
Please post any bugs you encounter, but before you do, check to see if it's already listed.
Thanks for your patience while we work to improve the community.
Followers 0
shadow100
help with free mods.
7 posts in this topic
i have been reading about the free mods for wr400 but the pictures of the carb i found dont look the same as my carb, there doesnt seem to be a throttle stop that stops full throttle. it is a 98 model wr400 is this model different, i have searched on here but cant seem to find the answer.
thanks for any help:worthy:
Says you are from across the pond... did the UK WR have the throttle stop on it from the factory?
If you bought the bike second hand the mod may have already been done. ask the previous owner if thats the case.
cheers
as far as i am aware its a german model. the previous owner doesnt know.
is there an easy way of checking if its been done?
I think your best bet is to follow the instructions here and take the throttle stop you have and compare it to a YZF throttle stop...good luck mate!
The throttle stop screw is shown in your picture here. It looks like it has been backed out though, and I see some sort of thread locker on it. It is at the left hand side of the picture and goes up behind the pulley that holds the throttle cables. You will still want to compare it's overall length with a YZ throttle stop unless you can get someone to give you the measurements. Hope this helps.
Josh
i have found the measurements from the link prime gave me so i will give that a go and check see if it has already been cut down.
thanks for your help
Followers 0
