would this be a good way to test my starter
I i was to remove the toque limiter and hit the e-start button and listen for the squealing. would that be a good way to test to see if the squealing is the starter or the starter clutch.
i don't thinks it would hurt. If I were in the same position as you trying to identify a problem, I would probably do it just to see if I can isolate the problem.
Yep.... I say do it, what can go wrong?
did it. The problem was the starter motor!
I'd be willing to bet its just dry bushings. If you can carefully take it apart, some light to medium oil on it will probably fix it.
