Lengthening a chain?
If I wanted to get rear tire back a bit more, should I try to lengthen the
existing chain or do I have to replace it?
If you have the spare links and a tool you could certainly do it. I've also known some people to run multiple clipped masters, but loads of peeps will recommend against that!
Sure you could make the chain longer with some links.
If it works, when you replace your chain and sprokets, trim down the new chain to the new link count.
