HEADS UP!!!
Site upgrade in progress... Core site functions are working, but some non-critical features/functions will be temporarily unavailable while we work to restore them over the next couple of weeks.
Please post any bugs you encounter, but before you do, check to see if it's already listed.
Thanks for your patience while we work to improve the community.
Followers 0
TuningFork426
Wiesco Pistons ???
13 posts in this topic
Yup. 13.5:1. Alittle noisier than stock (you run a little looser clearance for forged pistons), but works well
what do u mean by looser clearence? the space between the skirt and the wall?
Yes, that's it. Forged pistons expand a bit more than cast do, so they run looser skirt to wall clearnace.
Yes, they last as long...maybe longer. With a std bore, 13.5:1 and hot cams , I could run pump gas. Wiht a 444 big bore, 13.5:1, and the same hot cams, I have to run a 50/50 mix of C12 and pump premium to keep the dreaded dingles away
You won't be disappointed with the 13.5:1 piston. It really wakes up the 426. I do, however, use race gas because she will ping with pump gas. :lol:
Been using them for 30+ years on both 2 stroke and 4. Great piston!
You CANNOT run pump gas and think your making more power than C12.. You have to rejet so rich so it does'nt detonate thus getting black color at the back of the muffler.. I run C12 and my muffler is grey... Do you know why??? CAUSE IT HAS LEAD!!! Good for the valves and the engine cylinder runs cooler..
Followers 0
