Need a couple measurements from you 650l guys...
I'm about to order a custom camper shell, and I need to make sure a BRP (which I don't own, YET) will fit through the door, the measurements will also help me buy a hitch receiver mounted motorcycle carrier, I want to be able to carry a bike inside or out.
Measurements I need:
1- Total height, from the ground to the highest point, not counting mirrors.
2- Total length. I guess different tires could through this off an inch or two,
that's close enough.
3- Wheelbase. I have seen a couple different numbers published, I guess this
number is measured from hub-center to hub-center.
4- Width of handlebars. Are the aftermarket bars any wider?
Thanks a ton, folks.
Here's some measurements for a XR650l ('05)
1: total height 50" (top of perches) 48" (top of headlight shroud)
2: total lenght 85"
3: wheelbase 58"
4: widht of bars 31 (w/o handguards) 32 (w/handguards)
remember that these measurements may vary from bike to bike but must be within an inch or so from these.good luck with your new brp:thumbsup:
Isn't a hitch type reciever made to carry smaller lite weight bikes? A 650L is up in the 350lb range when wet.
Thanks for the measurements, one less roadblock out of the way on my little camper project.
I have a classIII Drawtite on my truck, rated for 500lb tongue weight.
A wet 650l (with bigger tank) plus the weight of the rack itself should run about
425-450lbs, I should be okay.
I could upgrade hitches to a classIV, if I think its weak, or maybe add two more tubes on the side of the hitch to support the bike rack in three points...
