HEADS UP!!!
Site upgrade in progress... Core site functions are working, but some non-critical features/functions will be temporarily unavailable while we work to restore them over the next couple of weeks.
Please post any bugs you encounter, but before you do, check to see if it's already listed.
Thanks for your patience while we work to improve the community.
Followers 0
MTFYR
Excel Rim Spoke Torgue Settings
7 posts in this topic
Hello All,
I have a new Excel Rim, with Buchanan Spokes
stock hub. I bought a new torque wrench and
did my research. I'm going to figure out how to
do this trueing thing.
What is a good torque value for this set up. The
manual state 2.9 for spokes, that has to be a
mis-print. I've only seen one other value in the
search and came up with 48ft-lbs but didn't state
what their set up was.
Thanks for the help!
I just had my troublesome Excels that were laced to OE hubs with Buchanan spokes reworked by Buchanan with larger Buchanan spokes. Robert Buchanan himself told me 60-70 inch lbs for the front and 65-75 inch lbs for the rear. I adjusted my Fasst wrench to 65 and I haven't had a problem since.
Buchanan did not do my Excel wheelset originally........I should have known better.
Hello All,
I can't imagine 48 ft-lbs of torque ....must be a typo..:mad:
:mad: :mad:
Thanks All, Will give it the college try.
It is NOT 48 "ft.lbs"!!!
"2.9" is the correct spec in the manual, and is stated as "ft.lbs.". If you bought a spoke-specific torque wrench, odds are real good it is calibrated in "inch pounds". 2.9 ft.lbs. converts to 34.8 inch-pounds (2.9 X 12).:mad: That's spec for the factory spokes.
The Buchanon spokes may require a higher torque, I can't say, but I can promise you they don't require 48 foot pounds.
Bubba, you torque your spokes to 48 "foot pounds" and you are going to have one freaking wobbly rim.:worthy::ride:
Okay?!! :mad: :mad:
"2.9" is the correct spec in the manual, and is stated as "ft.lbs.". If you bought a spoke-specific torque wrench, odds are real good it is calibrated in "inch pounds". 2.9 ft.lbs. converts to 34.8 inch-pounds (2.9 X 12). That's spec for the factory spokes.
Yep you're right it's 48 in. lbs.
Followers 0
