Followers 0
Old_Yeller
How do you remove fork oil?
2 posts in this topic
What's an easy way to lower my fork oil height? Can I do it through the bleed hole or do I have to take the forks apart? Does the top just screw off?
Thanks in advance...
Take the bars off {not the controls} and just lay them over. Take the top cap off and separate it from the lower tube. You will need to support the tube from below. Remove the spring. Use a large syringe and piece of fuel tube or other hose to remove the oil you need to. You can get the syringe form an auto parts store. If you are unclear Check your manual for disassembly of the forks.
Followers 0
