WR400/426/450 Jetting Database
Year: 2002
Model (400 - 426 - 450): 426
Cam Timing (WR/YZ): Decomp cam, don't know if it's WR or YZ
Main jet: 168
Pilot Jet: 42
MAJ: 200
PAJ: 75
Leak Jet: NA
Starter Jet: 65
Fuel screw (turns out): ~2 1/2
Needle Model/Clip position: OBEKQ 4th clip
Grey Wire Mod (Y/N): NA (NZ model don't have it to stat with)
TPS Connected (Y/N): Y
Airbox Snorkel/Lid (on or off): off
AIS Removed (Y/N): ?
Airfilter Brand: Stock
Exhaust Brand: Staintune
Average Altitude: 0-1000 ft
Average Temperature: 5-25 deg C (41-77 deg F)
Average Humidity: 60%
Degree of Satisfaction (0-10): 4 (hopefully will be a 10 when I sort out the jetting)
Additional Mods/Comments: BK mod to bring AP squirt down to 1/2 a second (was about 2 seconds). Idles alright, stumbles all over the place at 1/4 - 1/2 throttle (needle I'm guessing, kinda new to this tuning thing, probably gonna get the JD kit), pulls strong at 1/2 - full throttle but a little on the lean side (plug test). Only just bought the bike, need to get this jetting sorted out so I can see what it really can do!
  • 2 months later...
Year: 2005
Model (400 - 426 - 450): 450
Cam Timing (WR/YZ): stock - WR
Main jet: JD - 165
Pilot Jet: stock - 45 (I think)
PAJ: stock - 80
Leak Jet: stock - 50
Starter Jet: - stock - 65
Fuel screw (turns out): zipty - 1 1/4
Needle Model/Clip position: JD - red 4th from the top
Grey Wire Mod (Y/N): YES
TPS Connected (Y/N): YES
Airbox Snorkel/Lid (on or off): OFF
AIS Removed (Y/N): YES
Airfilter Brand: TwinAir
Exhaust Brand: Stock w/ GYTR Performance WR Muffler Insert
Average Altitude: 6000-10000
Average Temperature: 60-80
Average Humidity: DRY
Degree of Satisfaction (0-10): 10 - I LOVE THIS BIKE! ?
Additional Mods/Comments: Suspension re-sprug and re-valved for a 210 lb B Enduro rider, Rekluse clutch w/perch adjuster, 14-49 gearing, DID X-Ring chain and Renthal sprockets, Acerbis 3.3 gal tank...
I love this bike... I tried putting an 06 YZF exhaust cam in it and it just killed the bottom end.....so I don't recommend it...
  • 3 weeks later...
Year:'07 WR450F
Cam Timing (WR/YZ):WR
Main jet:165
Pilot Jet:45
PAJ:Stock
Leak Jet:40
Starter Jet:Stock
Fuel screw (turns out):ZipTy 1.5 Turns
Needle Model/Clip position: JD Red 4th slot
Grey Wire Mod (Y/N):y
TPS Connected (Y/N):y
Airbox Snorkel/Lid (on or off):off
AIS Removed (Y/N):y
Airfilter Brand:stock
Exhaust Brand:stock uncorked w/sparky
Average Altitude:1500-5000
Average Temperature:75-100
Average Humidity:under 20%
Degree of Satisfaction (0-10):So far 9, as there is always room to improve. I love this bike.
Year: 2001
Model (400 - 426 - 450): WR 426
Cam Timing (WR/YZ): WR timed
Main jet: 168
Pilot Jet: 45
PAJ: 100
Leak Jet: NA
Starter Jet: 65
Fuel screw (turns out): 2 turns out
Needle Model/Clip position: JD Red #4
Grey Wire Mod (Y/N): Yes
TPS Connected (Y/N): Yes (not re-adjusted from factory)
Airbox Snorkel/Lid (on or off): Airbox lid off
AIS Removed (Y/N): NA
Airfilter Brand: Twin Air w/ No-Toil Oil
Exhaust Brand: Stock, with GYT-R Insert
Average Altitude: 700ft (Michigan)
Average Temperature: 70-90 F
Average Humidity: 70-90%
Degree of Satisfaction (0-10): 9 (we can always want more can't we?)
Additional Mods/Comments: Additional mods:
Light Blue Wire
O-Ring Mod (WAY better than BK Mod for me)
ACV disabled (which is why I have a 100 PAJ rather than a 75 stock)
Just did the O-ring mod, and it took my degree of satisfaction from a 6 to a 9!! Can't say enough about the difference it made. Almost made it run like an open exhaust.
  • 1 month later...
Year:2007
Model (400 - 426 - 450):450
Main jet:168 (162 stock)
Pilot Jet: 48 (45 stock)
PAJ:Stock
Leak Jet:Stock
Starter Jet:Stock
Fuel screw (turns out):MSR 1.75 out
Needle Model/Clip position:JD red/4th
Grey Wire Mod (Y/N):Y
TPS Connected (Y/N):Y
AIS Removed (Y/N):Y
Airfilter Brand:Twin air
Exhaust Brand:'07 YZ header/ White Bros. E2 muffler
Average Altitude:sea level to 6500ft
Average Temperature:55-100 degrees F
Average Humidity: Across the board
Degree of Satisfaction (0-10):So far 12/10!
Shes unleased now. Everything that everybody says about the WR 450f with an aftermarket exhaust is true. I'm super stoked
Year:2002
Model (400 - 426 - 450):426
Main jet:170
Pilot Jet: 45
PAJ:Stock
Leak Jet:N/A
Starter Jet:Stock
Fuel screw (turns out):1.75
Needle Model/Clip position:JD red/5th For Summer 120 degree heat. Winter see below.
Airbox Snorkel/Lid (on or off): Snorkel Out, Lid Modified
AIS Removed (Y/N):N?A
Airfilter Brand:Twin Air
Exhaust Brand:Stock header muffler FMF PowerCore4
Average Altitude:sea level to 2000'
Average Temperature:45-125 degrees F
Average Humidity: 5-100 Percent
Degree of Satisfaction (0-10):So far 10/10.
Additional Mods/Comments:Thick o-ring mod from the JD kit.
Come Winter I will change out to Blue Needle on 3rd clip. And see if rest of jetting will be fine where it is.
  • 1 month later...
Year: 07
Main jet: 168
Pilot Jet: 48
PAJ: 110
Leak Jet: 45
Starter Jet:
Fuel screw (turns out): 1.5
Needle Model/Clip position: red/4
Grey Wire Mod (Y/N): y
TPS Connected (Y/N): y
AIS Removed (Y/N): y
Airfilter Brand: uni
Exhaust Brand: gytr 96db performance insert, p/n gyt-5tj93-75-01:
Average Altitude: 2-4000'
Average Temperature: 80
Average Humidity: low
Degree of Satisfaction (0-10): 9.5
Additional Mods/Comments: first I installed Yamaha AIS kit and found it to be a little rich for me. Bought the JD kit and installed per instructions, thick oring mod. very happy with this setup. left the gytr main air jet and leak jet installed.
Year:2007
Cam Timing (WR/YZ):WR/STOCK
Main jet:170
Pilot Jet:48
PAJ:STOCK
Leak Jet:STOCK
Starter Jet:STOCK
Fuel screw (turns out):1.50
Needle Model/Clip position:AIS NEEDLE #3
Grey Wire Mod (Y/N):YES
TPS Connected (Y/N):YES
Airbox Snorkel/Lid (on or off):OFF
AIS Removed (Y/N):YES
Airfilter Brand:TWIN AIR
Exhaust Brand:FMF FACTORY 4.1 SLIP ON
Average Altitude:1200 METERS
Average Temperature:25 CELCIUS
Average Humidity:40-60%
Degree of Satisfaction (0-10):10
Additional Mods/Comments:NOW MY BABY IS ALIVE!!!!
  • 2 weeks later...
Year: 2007
Main jet: 165
Pilot Jet: 45
PAJ:
Leak Jet: 45
Starter Jet:
Needle Model/Clip position: Red needle 4th from top
Exhaust Brand: White Brothers E2 slip on
Average Altitude: 0-4000' asl
Average Humidity:
Additional Mods/Comments: This site helped alot for jetting purposes. No bogs, starts first kick.
  • 1 month later...
Model: 2006 WR450F
Cam Timing: WR (stock)
Main Jet: 168 (165 is stock)
Pilot Jet: 48 (45 is stock)
Fuel screw: GYTR - 2 out (about)
Needle model/Clip position: 4th pos on needle from GYTR AIS kit
Starter Jet: 65 (stock)
Leak Jet: 40 (50 is stock)
Airbox lid (on or off): snorkel removed, holes in side of box
AIS: GYTR AIS removal kit
Pipe: FMF Q w/ S.A.
Air filter: UNI Multi-Stage
Altitude where you ride: Sea level to 4000
Temperature where you ride: Varies, mostly 70s-80s(Jawbone)
Degree of Jetting satisfaction: Need to test, will report. :crazy:
  • 2 weeks later...
Year: 1999
Model (400 - 426 - 450): 400FL
Cam Timing (WR/YZ): YZ
Main jet: 168
Pilot Jet: 45
PAJ1: 75
PAJ2: 90
Main air jet: 200
Leak Jet: N/A?
Starter Jet: 60
Fuel (pilot) screw (turns out): 1.5 (still tuning)
Needle Model/Clip position: OBDTM(stock)/4
AIS Removed (Y/N): N/A
Exhaust Brand: stock YZF426
Average Altitude: 0ft
Average Temperature: 80F (27C)
Average Humidity: 70%
Additional Mods/Comments: Also have home made AvNow installed (1/4 and ½ open plates). Mostly stock setup, with ZipTy fuel (pilot) screw. Starts w/o choke on 2nd kick. No hesitation/bog, instant throttle response. Linear power band, no peaks or dips. No afterfire (backfire) after changing clip from position 3 to 4.
  • 3 months later...
Year: 2008
Main jet: JD 168
Pilot Jet: JD 48
PAJ: YEC AIS 110
Leak Jet: YEC AIS 45
Starter Jet:
Fuel screw (turns out): MSR 2
Needle Model/Clip position: JD red/4
Exhaust Brand: Stock, unplugged
Average Altitude: SEA - 2000'
Average Temperature: 45-55 (So Far)
Degree of Satisfaction (0-10): 8
Additional Mods/Comments: W/ Small JD O-ring MOD - This is a combo of the YEC AIS kit and a JD Jet Kit. Runs great, no bogs, but I only got 27.3 miles until I had to switch to reserve. Will try leaning it out a bit and update.
  • 2 weeks later...
Year: 2007
Main jet: 168
Pilot Jet: 48
PAJ: 70 (stock)
MAJ: 110
Leak Jet: R&D power pump set at approx. 40
Fuel screw (turns out): Zip-Ty 1.5
Needle Model/Clip position: JD Red 4th clip position
Accel. Pump O-ring MOD (Y/N): Y
Airbox Snorkel/Lid (on or off): Off
Exhaust Brand: Stock w/GYTR insert
Average Altitude: 800'
Additional Mods/Comments: R&D power pump is great for fine tuning the leak jet to get rid of that off-idle bog and just needs slight adjustments for Summer vs. Winter operation!
  • 4 weeks later...
Year: 2008
Cam Timing (WR/YZ): wr
Main jet: 168
Pilot Jet: 45
PAJ: 110
Leak Jet: 50
Starter Jet: 68
Fuel screw (turns out): stock 1.5
Needle Model/Clip position: GYTR AIS 4
Airfilter Brand: stock
Exhaust Brand: stock pea shooter removed
Average Altitude: 4000 to 6000 ft
Average Temperature: mid 50's right now
Average Humidity: 20-30%
Degree of Satisfaction (0-10):9
Additional Mods/Comments: still have a slight hesitation off idle, but have barely done a short break-in ride.
Year:2000
Model (400 - 426 - 450):400
Cam Timing (WR/YZ):YZ
Main jet:178
Pilot Jet:48
PAJ:75
Leak Jet:
Starter Jet:65
Fuel screw (turns out):1 1/4
Needle Model/Clip position:stk needle, 3rd position
AIS Removed (Y/N):N/A
Airfilter Brand:UNI
Exhaust Brand:stk with baffle removed
Average Altitude:1000-4000
Average Temperature:50-70
Average Humidity:
Additional Mods/Comments:homemade power now. runs great, no bog, instant response, starts 1-2 kicks everytime
  • 2 weeks later...
Year: 2007
Model (400 - 426 - 450): WR450
Main jet: 168
Pilot Jet: 48
Leak Jet: Set at 40 (R&D Power Pump with ALJ)
Starter Jet: 65 (Stock)
Fuel screw (turns out): GYTR Fuel Screw 2 Turns Out (still tuning)
Needle Model/Clip position: JD Red / 4th Position
Airfilter Brand: Uni
Exhaust Brand: Dr. D Full Race
Average Altitude: Sea Level
Average Temperature: 80 - 90 F
Degree of Satisfaction (0-10): Will be testing this weekend
Additional Mods/Comments: R & D stiffer spring installed on AP linkage arm.
Model (400 - 426 - 450): 2007 WR450
Timing (WR-YZ): WR
Main jet: 165
Pilot Jet: 45
Fuel screw (turns out): ZipTy - 1.5 out
Needle model/Clip position: JD red 4
Airbox lid (off): snorkel removed
Pipe: Stock header, FMF Q4
air filter: Stock
Altitude where you ride: 2500 - 5,500 ASL
Temperature where you ride: ~50 - 85 degrees.
Degree of satisfaction 9.9
  • 2 weeks later...
Year: 2007
Main jet: 168
Pilot Jet: 48
All other jets from the GYTR AIS kit installed
Fuel screw (turns out): Zip TY 1.5
Average Altitude: 0-500ft
Average Temperature: 70-90, but 50 right now
Additional Mods/Comments: O-ring'd the AP arm linkage too. No off idle hesitation, a little popping here and there at 1/2 to 3/4 throttle, couple twists would clean it up. Didn't seem to have any related power loss. Have only put on about 40 miles so far. Very happy with overall performance and rideability.
  • 3 weeks later...
Year:2001
Model (400 - 426 - 450):wr426
Cam Timing (WR/YZ):yz
Main jet:168
Pilot Jet:62
PAJ:60
MAJ:200
Leak Jet:stock
Starter Jet:stock
Fuel screw (turns out):2 1/2 turns out
Needle Model/Clip position:jd blue 2nd clip from top
Grey Wire Mod (Y/N):n
AIS Removed (Y/N):y
Airfilter Brand:twin air
Exhaust Brand:dr.d full stepped system
Average Altitude:1000m above sea level
Average Temperature:20c
Average Humidity:50-70%
Additional Mods/Comments:wisco 13.5:1 comp piston, port an polished head,full dr.d exahust system, alot of bling added to carb. these mods made the bike come to life.?
Re: JETTING D-Base WR400/426/450
Year: 2005
Main jet: 170
Pilot Jet: 48
PAJ: stock
Leak Jet: plugged
Starter Jet: 75
Fuel screw (turns out): Pro Circuit 1.5 - 2
Needle Model/Clip position: Stock 2005 YZ NFLR middle clip (up or down 4)
Airbox Snorkel/Lid (On/Off): Off
AIS Removed (Y/N): Yes
Airfilter Brand: UNI
Exhaust Brand: Stock 2005 YZ450
Average Altitude: 350 - 1000
Average Temperature: 75
Average Humidity: 45%
I live in Western KY. This should work in the News Channel 6 viewing area. I'm also using Sunco 110 because I keep getting bad gas from all the gas stations in town. It will rip. I plugged the leak jet with a ball I cut off of a pull-chain from a lamp. Drop it in a screw the leak jet in. It sticks up but does affect anything. I also have the AP set to where when the throttle is wide open, the rod is at the bottom with maybe a sheet of papers thickness between the screw and plastic piece on the AP.
