HEADS UP!!!
Site upgrade in progress... Core site functions are working, but some non-critical features/functions will be temporarily unavailable while we work to restore them over the next couple of weeks.
Please post any bugs you encounter, but before you do, check to see if it's already listed.
Thanks for your patience while we work to improve the community.
Followers 0
bobs450
JD Jetting Instructions pdf - 05 wr450
4 posts in this topic
Does anyone have a pdf (or scanned) copy of JD jetting instructions for a 05 wr450?
To make a long story short, my bike was stolen so I threw out a lot of my stock stuff and my JD instructions / box.
I got my bike back and now I ride in higher altitude locations 8-10K feet and my bike is backfiring and not as responsive as before (was riding usualy at 2-4K feet).
I tried contacting JDJetting@comcast.net a week ago but haven't heard back and I need to get this dialed in before I go out again.
Thanks, Bob
http://www.thumpertalk.com/forum/showthread.php?t=90530&highlight=jetting
and this is the best info i havew found. i converted it to C from F. sorry, dont hanve the F any more.
INDY_450's jetting chart:
Elevation 0 to 4,000. feet
-2c to 7c : 172 main, JD Blue #5, 48 Pilot, 2.0 turns, 75 starter jet, #0 leak jet
8c to 16c : 170 main, JD Blue #4, 48 Pilot, 1.75 turns, 72 starter jet, #0 leak jet
17c to 25c : 168 main, JD Blue #3 or JD Red #5, 48 Pilot, 1.5 turns, 70 starter jet, #40 leak jet
26c to 33c : 165 main, JD Red #5, 48 Pilot, 1.25 turns, 68 starter jet, #50 leak jet
34c plus : 160 main, JD Red #4, 45 Pilot, 2.0 turns, 65 starter jet, #60 leak jet
Elevation 4,000 to 8,000 feet:
-2c to 7c : 170 main, JD Blue #4, 48 Pilot, 1.75 turns, 72 starter jet, #0 leak jet
8c to 16c : 168 main, JD Blue #3, 48 Pilot, 1.5 turns, 70 starter jet, #40 leak jet
17c to 25c : 165 main, JD Red #5, 48 Pilot, 1.25 turns, 68 starter jet, #40 leak jet
26c to 33c : 165 main, JD Red #5, 45 Pilot, 2.0 turns, 65 starter jet, #50 leak jet
34c plus : 160 main, JD Red #4, 45 Pilot, 1.75 turns, 65 starter jet, #60 leak jet
Elevation 8,000 to 11,000 feet: ( Note powerloss due to altitude but your bike will idle!)
8c to 16c : 165 main, JD Red #5, 48 Pilot, 1.25 turns, 70 starter jet, #40 leak jet
17c to 25c : 160 main, JD Red #4 , 45 Pilot, 1.75 turns, 68 starter jet, #50 leak jet
26c to 33c : 158 main, JD Red #3, 45 Pilot, 1.5 turns, 65 starter jet, #60 leak jet
Thanks for passing this along. I also fould the original thread. Do you know if these settings are the same as what JD recommends?
Now i'll take a look at my carb as I forgot what I originally changed. Looks like I should also remove the smog pump as well.
Thanks again!
is this chart similar for the 250f or different, cos my MJ is 180 and im usually between 0-2000 ft
Followers 0
