Followers 0
wilbwil
Problems starting
3 posts in this topic
I tried to start my 05 wr450 today after a long winter in the garage. It's always been a bit of a hard start but it won't kick start of electric start at all. Any suggestions.
Pull the spark plug out try to turn over with the kick start, with the ignition off! If gas in the cylinder has locked up your engine you don't want a spark. I hope its that easy.
change your spark plug. And clean your carb. Your carburetor has become varnished from stagnate fuel. Pull it apart and clean it thoroughly replacing any o-rings and gaskets, and setting the float level. :thumbsup:
Followers 0
