irondude...
1. does your strengthened sub-frame and the SRC.net subframe extender and the Baja Designs LED license plate holder work with the acerbis secondary gas tank that is mounted under the seat? it looks like the tank eliminates the OEM rear fender.
2. when full, does this tank effect handling? did you have to reset your sag because of it?
3. is welding works in orange doing a business of strengthening sub-frames? i.e. if i sent mine to them, would they know what to do? or is it still a one-off kind of thing for them?
4. how did you get the dual rear brake lights to mount? it appears as though they mount on top of the BD LED license plate holder...
5. turn signal switch... it appears to be off a 650l... am i correct? i plan on using the same.
thanks,
TC
