Followers 0
moach1
popping on decel
2 posts in this topic
i cut the grey wire, removed snorkle, and i cut the throttle stop. i still have poppin when i let off the gas. what can i do? do i need to jet it? it popped since i bought, stock.
If it has a stock exhaust , the first and easiest thing to try is to be sure that the mid pipe clamp is tight. Then check the bolts that hold the header to the head. If these are loose, an air leak wil result and cause this.
If that's not it, try adjusting your idle mix a bit richer by a quarter turn or so.
http://www.thumperfaq.com/jetting.htm#PJ :cry:
Followers 0
