Tire Pressure?
Simple question. i am sure there is a post about this but thought i would try and get some new info... What PSI do you guys normally run in you tires and does it differ depending on the type of riding, such as trails, or mx track with big air. I know the tires say 15 psi but do any of you all actually use that much?
It depends on a few other things as well. Current temp outside, humidty and so on
I normally will run between 10 and 12 psi on my 756's depending how the tires are working that day and the weather
Here is a good link to read up on
Tires
I run 12 in the front and 10 in the back.
I run about 7 in the rear on my 756 and 10-12 in the front on the 739F.
