HEADS UP!!!
Site upgrade in progress... Core site functions are working, but some non-critical features/functions will be temporarily unavailable while we work to restore them over the next couple of weeks.
Please post any bugs you encounter, but before you do, check to see if it's already listed.
Thanks for your patience while we work to improve the community.
Followers 0
mnovarossi
Holy Cow! My Head Is Shot!
6 posts in this topic
What a bummer. My 2001 426 was making a noise I was not familiar with so I figured it was time for a valve check. It might have had 10 hours on it since it was rebuilt by a dealer mechanic because of timing chain breakage. The intake valves were so tight I could not get any feeler gauges in to check clearance. So I took the chain off and the intake cam wouldent even spin. The bolts to the cam cap seemed really tight, but its hard to tell with a short wrench. After I pryed the cam out of the cap I discovered the cap and head are egged out.The bearing is fine. The head journals are so mushroomed that I cant remove the buckets from the springs. What could have went wrong? The oil is changed every ride faithfully. There was oil in the cam cap, so I assume its getting oil and the exhaust cam is fine and that is lubbed after the intake cam. What else should I check? I'm worried about the valves, and my wallet. :thumbsup:
Go back and ask the Mechanic how he tightened the cam caps. If he didn't use a torque wrench chances are that is the cause.
If the caps are overtightened you loose the clearance between the caps and the cams and the cams bind in the journals. The end result is egged out journals.
I checked my valves and put it back together without a torque wrench not thinking that it was all that important. Soon my cam journals looked exactly like you described with no clearance between the cam and bucket.
Followers 0
