Finchy637
2016 YZ450FX exhaust and mapping
35 posts in this topic
I just bought a Dr. D full exhaust for my bike and I've been looking around to try and find some mapping tips after I install the kit. I have the tuner. I've never mapped before but don't feel like spending the extra money to have the shop do it for me because the shops around me charge an arm and a leg. Any tips or advice? I live at 5000ft above sea level and I don't ride tracks as of right now.
The stock exhaust is restrictive and does not have a spark arrester. So why not solve two problems at once. Plus the exhaust I bought is louder
It's a bit inaccurate to call the stock exhaust restrictive, and the fact that the new one is louder is not a positive.  The only thing about the stock pipe that needs to be addressed is the small reduction in diameter at the open end that was done to reduce noise to the required levels, which cuts a little bit into the very top end of the rev range.  Otherwise, the stock pipe's only disadvantage is that it's slightly heavy.
Typically, excluding the '08-'09 shorty exhaust, aftermarket pipes will add no more than 2 hp tops to any otherwise stock YZ450, usually less.  Their benefits often come more in the form of wider torque curves and such rather than raw gain, and most of them require very little fuel adjustment.
2 people like this
The big factor as well is they do not have a spark arrested which is required by law in my state as well as many states. The hp gain helps improve the hp to weight ratio as long as you are performing other weight reduction. As far as the torque curve is greatly needed seeing as I live in a valley with nothing but mountains around me and other plus is that the after market exhaust to me looks better than the stock and has a better crisper exhaust note.
1 person likes this
With a pro Moto billet end cap for around $150. You get about the same as any aftermarket perforated core straight through exhaust with a spark arrestor on that bike. Well other than looks and weight.
I saw no need to replace the stocker.  A S/A is required in AZ also, so for $142 bucks I got the PMB.  It's a quality item.  Looks great and certainly no louder than stock.
I wish I would have known about that sooner I already have the full exhaust kit just have to install it this afternoon
Ah nothing wrong with a new pipe either.
2 people like this
Yeah I'm pretty happy about it. My buddy has one on his 09 yz450 and loves it so I'm ready to see what it will do
How much does that cap weigh ?  It looks heavy.
It's really insignificant.
1 person likes this
So for those running the stock exhaust on the FX, are you finding any benefits to playing with the mapping?  I don't have the bike yet, but I found a deal I couldn't pass up on a GYTR tuner so I went ahead and bought it.  I figure if worse comes to worse I can break even by re-selling the tuner.  Hoping to get my KX sold in a jiffy so I can go pick up an FX :D
How many hours you got on the bike already? Let us know the difference between the 2.
I've been playing with the mapping on my FX and wondering if y'all could give me a few pointers. I'll attach a photo of the settings I'm currently using. I can't remember where I got them from but it was from one of the dirt bike magazine websites I believe. The problem is, the bike seems to run really hot. I have an FMF 4.1 RCT muffler with stock header. Are my settings way lean? Should I go to 0 or +1, +2, etc? Is the stock "0" map richer than what I currently have loaded in my bike? I think that is probably the biggest question I have. I'm not sure if + is a softer hit or -. I was thinking - was but I'm thinking I'm not correct.
Thanks!
Edited by jwilson32
1 person likes this
  • Similar Content
    • By C-P
      Looking for the 2009-specific head pipe for 09 YZ250F.  Let me know what you have, thanks!
    • By Lachie carwo
      does anyone know if a 1997 Yamaha WR250z is legal on your L's/LAMS?
    • By owainyz03
      Hey folks,
      I'm delighted to be back in the YZ 2 stroke forum after a bit of an absence. I used to own a 03 YZ 125 which always regret selling. I currently own a 2011 yz 250f and owned a 03 rm 125 until recently when I sold it to a friend. Only a few weeks later I got the 2 stroke itch and began looking for a 06+ YZ 125, after being blown away by the SSS suspension on the 250f. A few came and went that I missed out on but finally one popped up. Advertised as a 2007 yz 125 (vin checks as a 06) priced at  2500 Euro. The usual BS advertised was on the ad "good tires only one ride, chain and sprockets good etc " Arrived down and found the chain and sprockets absolutely shot, tires were worn, Leaky fork seals(looked like new oil?) rear fender broken few bits and pieces. Talked him down to 2200 euro and was happy enough with that. Picked it up on friday on my way home from college and started ripping it apart. And that's where things go down hill
      Found the air filter in a shocking state (see pics) which caused a major groan.... still at least its a 2 stroke. From looking in the exhaust and intake ports I could still see crosshatching very clearly, unfortunately I didn't have time to rip the cylinder off yet. Counter shaft seal appears to be weeping so that will get replaced, also isn't there an issue with 06 shift stopper or something? It does have unbreakable levers which is one of the few plus's
      All of the bearings will be inspected and replaced if necessary, new top end most likely, new bars, grips, tires, fork seals, chain and sprockets, air filter, restyle plastics more than likely and whatever else I uncover
      Keep in mind this will be a slow build as I'm in college 5 days a week.
      Now some pics
    • By Joseph18roberts
      My dirt bike was driven daily no issues besides petcock leaking a little gas and one day It quit running while I was riding it and started acting up the next day I tried and it would start but it wouldn't idle I would have to rev it high to stay running and it would backfire real bad this was a couple months ago anyone know what could be the issue if so let me know please gonna look at it tomorrow thank you in advance
    • By short450
      Very low hour rear shock for a 2010 - 2013 Yamaha YZ450F.  It was a back up shock and was valved by Enzo.
      Only asking $250!
      Call or text me at 801-36two-8899
