Clutch problems?
My 426 has had many problems, but here is a new one. I pull in the clutch and put the bike into gear and it won't roll like it is supposed to when I pull the clutch lever. It is like I don't even have the lever pulled. The cable I getting pulled far enough but it doesn't wanto roll... This is when it is shut off Any suggestions?
That's not really so abnormal.  The question is whether it releases in a functional manner when the engine is running.  If you can get it to go from in gear to neutral at an idle without an excessive amount of fuss, it's working about right.
Thanks! The reason I can't try that is because my water pump had issues getting fixed right now. But I will definitely use your advice.
