Need help with 07 wr450
Hi everyone,
I've just purchased a 2007 wr450 aluminium frame as a second/winter bike.
Only ever had sportbikes before so have no idea about these bikes.
First couple of things I can't find the answer to is will a slip on exhaust from the 06 steel frame bikes fit my 07 with ally frame?
And
I'm going to do a oil change at the weekend and want to know if I can use the same oil I use for my R1?
I use silkolene comp 4 in the r1, it has all the right specifications that the manual states for oil but I haven't found anyone recommending comp 4 for a wr so thought I'd check.
Appreciate any help
Hi everyone,
And
Appreciate any help
Any good quality motor oil will suffice so yes, the Silkoline will be fine....not sure about the pipe. Have fun
Hi everyone,
And
Appreciate any help
The pipe will fit, but the mount at the mid pipe will be in the wrong place. You can fabricate your own mount/clamp around the subframe if the pipe is a total deal. You can even do it with plumber strap.
Brilliant, thanks
Ah thats very tempting.
