Instant RPM!!
I put my thunder alley pipe on. while I had it semi-apart, I did the BK mod, raised the needle 1 notch, put a 168 main in it. The result? Blipping the throttle results in a blast of RPM I have never witnessed from a four stroke engine of any type or kind. I so excited Im almost scared. I actually set the pump timing with the engine running, blipping the throttle and give it a twist, blip it again etc. This seemed to yield best results for an unloaded reaction from the motor. One thing I did find that I didnt expect. Both of my throttle cables were frayed terribly. Is this common? The return cable was down to a single strand! Scary when thought of broken. :)
I have heard of a few frayed cables here. I have never had such a problem. I'm thinking it may be an alignment problem. Ty Davis sells a billet wheel that is supposed to eliminate the problem all together.
Ernie
Shawn - Yep, the mod makes a huge difference doesn't it :) Wait till you try her on the track!
Which end of the cable was frayed? My cable keeps getting looser and I keep tightening it and now you have me concerned that it's getting looser because it's getting frayed. :)
The cable thing: Yup it happens. At least it did on my '98 and a lot of my buddies '98s too. I assumed they fixed it. It gives you cruise control if it gets frayed bad enough. The cable(s) is $29.
The problem is with the bracket holding the ends of the cables. Once you get a good set of cables on, bend the cable bracket to insure a straight alignment coming and going to the pulley. Going to an aftermarket pulley won't cure the alignment problem.
:D:)
I actually zip-tied the cables together to help align them........after a $30 purchase of new cables!
the bracket must have been made in Afghanastan!
It is totally out of alignment. about a 10-15degree angle?????W.T.H?
why wouldn't yammy make it parallel?
zip ties help tons!
