Followers 0
number0six
99 YZ 400f backfiring!
3 posts in this topic
Hello long time reader…
So just got a 99 YZ400f and as mentioned in the title it backfires fairy bad through the exhaust when backing off and the header gets super-hot I assume from the popping?
Background- guy I got it from had it from new, he crashed messed himself up somewhat after about two years riding (he said no more than 100 rides) since then its sat in his shed. It starts no worries has a ton of compression and doesn’t seem to have any cracks in the header (all stock pipes).
I have not checked the valves yet.
Now I have read all the topics and know these are great for it and have pulled the carb apart and found that the jets have turned kind of green? What would cause this?
Is it just from sitting around for the past 8 years?
I’m planning on replacing all the jets and cleaning the carb completely but just thought I’d find out a few things first...
How hard is it to do? I’ve never played with these bits before...
I’m fairly mechanical minded but have a terrible history of starting a job while doing others and not finishing it straight away then forgetting what’s going on...
I just finished a quad a few months ago and have a road bike on the go too (nearly there) but this is what I want to be on :-)
All advice welcomed!
Tar...
Oh I am in Melbourne Australia and its hot hot summer here :ride:
Edited by number0six
The backfiring is due either to a leaking exhaust system at either end of the head pipe, and/or a lean pilot.
When brass turns green, it's usually water that did it. You most likely have a varnished pilot jet. Read:
http://www.thumpertalk.com/forum/showthread.php?p=8021726#post8021726
Then:
http://www.thumpertalk.com/forum/showthread.php?t=327405
my 99 400f backfired like a beast when i bought it. it had NO exhaust gaskets at all. threw some in, and no more backfires! easy and fairly cheap fix.
Followers 0
  • Similar Content
    • By Lachie carwo
      does anyone know if a 1997 Yamaha WR250z is legal on your L's/LAMS?
    • By owainyz03
      Hey folks,
      I'm delighted to be back in the YZ 2 stroke forum after a bit of an absence. I used to own a 03 YZ 125 which always regret selling. I currently own a 2011 yz 250f and owned a 03 rm 125 until recently when I sold it to a friend. Only a few weeks later I got the 2 stroke itch and began looking for a 06+ YZ 125, after being blown away by the SSS suspension on the 250f. A few came and went that I missed out on but finally one popped up. Advertised as a 2007 yz 125 (vin checks as a 06) priced at  2500 Euro. The usual BS advertised was on the ad "good tires only one ride, chain and sprockets good etc " Arrived down and found the chain and sprockets absolutely shot, tires were worn, Leaky fork seals(looked like new oil?) rear fender broken few bits and pieces. Talked him down to 2200 euro and was happy enough with that. Picked it up on friday on my way home from college and started ripping it apart. And that's where things go down hill
      Found the air filter in a shocking state (see pics) which caused a major groan.... still at least its a 2 stroke. From looking in the exhaust and intake ports I could still see crosshatching very clearly, unfortunately I didn't have time to rip the cylinder off yet. Counter shaft seal appears to be weeping so that will get replaced, also isn't there an issue with 06 shift stopper or something? It does have unbreakable levers which is one of the few plus's
      All of the bearings will be inspected and replaced if necessary, new top end most likely, new bars, grips, tires, fork seals, chain and sprockets, air filter, restyle plastics more than likely and whatever else I uncover
      Keep in mind this will be a slow build as I'm in college 5 days a week.
      Now some pics
    • By C-P
      Looking for the 2009-specific head pipe for 09 YZ250F.  Let me know what you have, thanks!
    • By Joseph18roberts
      My dirt bike was driven daily no issues besides petcock leaking a little gas and one day It quit running while I was riding it and started acting up the next day I tried and it would start but it wouldn't idle I would have to rev it high to stay running and it would backfire real bad this was a couple months ago anyone know what could be the issue if so let me know please gonna look at it tomorrow thank you in advance
    • By short450
      Very low hour rear shock for a 2010 - 2013 Yamaha YZ450F.  It was a back up shock and was valved by Enzo.
      Only asking $250!
      Call or text me at 801-36two-8899
