wanting to install a fan to cool radiators on WR 426 01
4 replies to this topic
  • Chaddlez
Posted January 13, 2013 - 03:46 PM
hi guys,
Im wanting to install a fan to help cool the radiators on a WR426 01 is this at all possible
Thanks,
  • MANIAC998
Posted January 14, 2013 - 03:18 AM
Yes, there are a few members here on TT that have done it. Do a search, and you should come up with quite a bit of info. Good luck!
  • DeepPurplishBlue
Posted January 14, 2013 - 12:09 PM
I believe the problem here is going to be that the wr426 does not have a battery and will not make much electricity at low RPMs which is where you will need the fan the most...
  • Birdy426
Posted January 14, 2013 - 11:02 PM
There's plenty of electrical powewr to drive a fan. The problem is that something high quality and durable like a Spaal or KTM part is too big to fit if you have an oversize YZ tank on, and something smaller, like an 80cm computer fan isn't reliable enough. If you havea stock WR tank or stock size YZ tank, you should be OK with a Spaal or KTM fan.
  • Chaddlez
Posted January 15, 2013 - 05:12 AM
Ok ill give it a go thanks BIRDY426
