My wr 400 rattles like a bag-a-rattles
7 replies to this topic
  • macross
Posted November 19, 2003 - 02:46 PM
My Wr 400 rattles.....I know they do a bit, mine seems to more than most !......2 types of rattles in fact.....the clutch, normal, & another that seems to be at the top end.....Im new to thumpers, its 2000 model & ive only been on the bike a couple of weeks so it's all quite new !!!!!!!! any advise ?.........please :)
  • Bamster
Posted November 19, 2003 - 03:07 PM
my 99 makes top end noise ,always has.
  • macross
Posted November 19, 2003 - 03:47 PM
Thanx mate. just makes me feel concerned when your used to 4 cylinder 4 stokes running like silk, I must say it does get quieter as you go !!! :)
  • Dan_Lorenze
Posted November 19, 2003 - 04:44 PM
None of my WRs ever rattled... I remember once when I had my CR250 my bike vibrated really bad and even rattled.. It turns out that the spokes were loose.. :) I tightend them up and no more rattle or vibration... It can't hurt to check... :D
  • macross
Posted November 20, 2003 - 11:50 AM
Thanx dude,
They were slack & I tightened um up when the bike came :D
but its the motor that worries me :)
  • GPS Dual Sport
Posted November 20, 2003 - 12:40 PM
Check your Cam Chain. My 98 WR 400 wore out a cam chain before the piston and rings.
You can confirm by pulling the cam over and see if the chain has been slapping it and leaving marks.
  • tctrailrider
Posted November 20, 2003 - 03:05 PM
My Wr 400 rattles
Two parts oil, one part Oat Meal, should do the trick. :)
  • x2smoker
Posted November 21, 2003 - 02:33 PM
I noticed a rather loud rattle after I put on a GYRT insert, before that it was too loud to hear anything. No one I knew could put a finger on it so I decided if it breaks...... well I'll know what it was then.
At an event, I started listening to all WR's and noticed that 9 of 10 rattled to varying degrees, most not a severe as mine, some worse. From that info, I mistook the rallte as normal.
Finally toward the end of this summer, about 1000 miles later, an intake valve broke. Damage incurred: about $1400.00 in parts.
If you don't find the problem elsewhere, I suggest you remove the head and have an expert give it a once over. Or wait like I did and pay the ultimate price. Although you don't hear much of broken WR/YZF valves here on TT, it appears to be not too uncommom after talking to mechanics and specialty shops.
