Honda
2006 TRX 450ER Problems
2 replies to this topic
  • zeeohh6ex
Posted January 04, 2013 - 06:11 AM
So recently I picked up a 2006 Trx 450ER from a friend of a friend. When I picked it up it would run but not idle he told me it had been sitting for about a year. since then I replaced the plug changed the fluids and the starter clutch and cleaned out the Carb and jets are spotless along with whole top side of the motor. Next my friend and I took apart the cover and found the intake valve to be super tight, We reshimmed it and put it back together. Now the Bike will sputter on for about 1-2 seconds but will not start. Gets a clean spark and Fuel and has compression. We rechecked the timing and its spot on. at this point dont really know what else to check and I'm about to remove the head.
any advice would be appreciated
  • Coueshunter
Posted January 08, 2013 - 09:38 PM
Start at basics, timing set properly? What are valve and decompression clearances?
  • MX450R
Posted January 09, 2013 - 07:30 AM
So when you bought it, it would start just not idle correct? You adjusted the valves now it wont start? Are you sure your in time. Not calling you out just very easy to get them out. I always take the plug out and drop a screw driver down the hole to ensure i am at TDC when my mark says i am. Then be sure your cam lobes are at about 2 oclock roughly. Gettin them 180 out seems to be acommon mistake. And the decompressor arm should be set at valve lash +.006 (should be around .017) not .025 like the CRF.
Honda Announces More 2017 ATVs by Bryan Bosch
ATV/UTV   General ATV/UTV Forums   General ATV/UTV Discussion
  • 0 replies
Honda
400ex went through a Flood by Austin_400ex
ATV/UTV   Make/Model Specific   Sport ATV
  • 2 replies
Honda
trx450er weak spark by ridinredneck
  • 2 replies
Honda
400ex studs/head gaskets by honda4
Honda 400EX Cutting out by Parker_B30
ATV/UTV   ATV/UTV Technical Forums   Intake - Jetting/Fuel Injection
  • 0 replies
