Piston Type
6 replies to this topic
  • Mark537
Posted January 01, 2013 - 07:29 PM
I got a ricky mountain gift card for the holidays and I have been wanting to rebuild the top end over the winter break. I cannot decide between these to kits (links below) If anyone could help or has used any in the past your advice is appreciated.
http://www.rockymoun...rtex-Piston-Kit
http://www.rockymoun...seco-Piston-Kit
  • DC_Excitement
Posted January 02, 2013 - 04:07 AM
easy, neither. go oem, same price if not cheaper than the wiseco kit. just look it up on there website. you just have to buy the parts individually.
  • indy rider
Posted January 02, 2013 - 04:53 AM
I've been running the Vertex BB pistons for a couple years now. They are very good quality...but if I was running a stock bore I'd go with OEM.
  • Stu2
Posted January 02, 2013 - 05:37 AM
+1 for OEM
  • Mark537
Posted January 02, 2013 - 07:36 AM
ok I will order oem. Can someone help me with a parts list or know where I can find one?
  • luckyguy19
Posted January 02, 2013 - 10:06 AM
Another vote for OEM Parts. These should be all you'll need for the whole job.
33D-116A0-00-00 Piston Kit (piston, rings, clips, wrist pin)
33D-11181-00-00 Head Gasket
33D-11351-00-00 Base Gasket
94591-57122-00 Cam Chain
4FM-12213-00-00 Cam Chain Tensioner Gasket
That should be everything you need. Might as well do a cam chain while your in there. You'll need a flywheel puller if you do the chain.
Edited by luckyguy19, January 02, 2013 - 10:09 AM.
  • mwmx54
Posted January 03, 2013 - 05:57 PM
its 10$ cheaper at rockymountain to piece together the piston kit than it is to buy the piston kit. for a 2010 that is. its like 135 for piston, clips, pin and rings.
  • 0 replies
  • Hot  36 replies
  • Hot  38 replies
  • Hot  47 replies
