Trying to ID a factory shock spring.
3 replies to this topic
  • Mike Maner
Posted January 01, 2013 - 12:30 PM
I bought a complete shock some time back from a fellow that was parting a WR bike out. My thought at the time was that the valving would be better for me than my factory 2003 YZ250 valving for woods riding. I've since had my shock revalved and would like to sell the shock and spring. I would like to identify the factory spring if possible. It's dark charcoal grey with a yellow paint dot. The wire diameter is .449". It's free length looks to be 10 5/16". Any help would be appreciated.
Mike
  • MANIAC998
Posted January 02, 2013 - 03:34 AM
The Yamaha manual has a section, I believe it's in Tuning, where you can look up the spring rate using the yellow dot code that you found on the spring. Just be aware that the stock springs used by all of the manufacturers have huge tolerances in there spring rate. Just because they call it a 5.0 doesn't mean it is! It can measure anywhere from 4.8 to 5.1, when actually measured!!
  • GuyGraham
Posted January 02, 2013 - 04:46 AM
Here you go
Type spring rate Spring Part no. ID Colour Spring Free Length
soft 4.3 5UN-22212-00 Brown 260mm
soft 4.5 5UN-22212-10 Green 260mm
soft 4.7 5UN-22212-20 red 260mm
soft 4.9 5UN-22212-30 black 260mm
soft 5.1 5UN-22212-40 Blue 260mm
soft 5.3 5UN-22212-50 Yellow 260mm
std 5.5 5UN-22212-60 Pink 260mm
hard 5.7 5UN-22212-70 White 260mm
Edited by GuyGraham, January 02, 2013 - 04:47 AM.
  • Mike Maner
Posted January 02, 2013 - 05:03 AM
Guys I really appreciate the help and the information you gave me. I hoping to be able to sell the shock with one of the three different springs I have and maybe help someone get their bike sprung correctly at the same time. Thanks again
Mike
