Oil level Question.
4 replies to this topic
  • zack_attack190
Posted October 30, 2001 - 03:40 AM
Hello,
Last weekend I could not start my bike. I was wondering about something, is it normal
for oil to be behind the ignition cover?
I checked the oil in the resivor and it seems like it was low. I was wondering if the
seal was leaking
Thanks
Zack
  • vaughn
Posted October 30, 2001 - 04:12 AM
Keep in mind that if you check the oil level without first running the bike for a couple of minutes it will read low. Mine will read about half the length of the hatched area on the dip stick higher after I run the bike. As far as oil behind the ignition cover, I'm not sure. Doesn't seem right unless there is some overflow vent somewhere.
  • xrracer36
Posted October 30, 2001 - 05:36 AM
i get a little (not much ) oil seepage behing that cover too...??? seems to run ok... my dad has that on his xr200, too. maybe just a leaky seal?... i'm not worried about it on my. the oil seems to stay pretty constant.
  • tuck
Posted October 30, 2001 - 06:50 AM
I read a product report on the Pro Circuit ignition cover and it was stated that it leaked oil out of the screw in plug.So I would think it is normal.
  • DaveJ
Posted October 30, 2001 - 07:58 AM
If you talking about the left engine cover, the answer is yes.
Which means if you pull the cover or any of the two plugs, oil will leak or get pumped out.
And yes, only check the oil after the bike has been run for about a minute.
DaveJ
  • Hot  33 replies
  • 5 replies
  • 0 replies
Motocross
  • Hot  491 replies
