Winter tuning
5 replies to this topic
  • yukondood
Posted December 29, 2012 - 08:52 PM
I have an 08 wr 450 with Timbesled with mt horse track kit. Work sweet most of the time. Biggest problem is mid to full throttle bog/hesitiation. Happens inconsistnently and only when under a load, rarely happens on the trial but happens when climbing a hill or in deep snow. Any suggestions on jetting at 3000-5000 feet -5 to - 15 celsius??
  • allterra
Posted December 29, 2012 - 09:05 PM
I am jealous. I think a conversion would be great. As it is I am running through a foot and a half of snow on studded tires. Not sure if I will be able to dig much more.
  • MANIAC998
Posted December 30, 2012 - 05:10 AM
What are you currently running for a main jet? I'd increase it a little in size from what you've got in there now, and see if that helps. Main jets are easy to change on these bikes.
  • Krannie McKranface
Posted January 02, 2013 - 02:11 PM
Hesitation is the Accclerator pump. 50 leak jet and an upgraded (merge racing) linkage spring.
Then adjust the squirt for perfect timing to always miss the slide.
  • MANIAC998
Posted January 02, 2013 - 05:24 PM
Possibly, but I'd try an easy to change main jet first.
  • revyrider
Posted January 04, 2013 - 07:30 AM
I am looking at a timbersled kit for my '07 wr450.Most guys around here use an MX bike for snow conversions-I was wondering if you have had any issues with the wider ratio trans & any other comments on your converted wr.
